Urgent: Installation instructions are not correct
in Xpert Posts: 6
Dear friends,
I just downloaded the Xpert theme but the installation instructions seems to be inaccurate:
Upload it via admin panel(can get error while upload on slower connections, or cause of other issues)
Download ZIP file from ThemeForest and find in it xpert.zip(theme file)
go to Appearance->Themes->Install Themes(Tab)->Upload and choose file xpert.zip
go to Appearance->Themes and click "Activate" below Xpert theme
The problem is that when I go to Appearance->Themes, there's no Install Themes option (see pic attached).
How can I solve this?
Thanks in advance,
Vilamiu
P.s.: I'm a big hurry to make this to work
    Is this wordpress.org domain?
    Can You please send me an url to your website?
  • Sure, it is www.vilamiu.com
    OK, from what i can see it's hosted on Wordpress.com server - is that right?
    if so - please refer to https://en.support.wordpress.com/themes/adding-new-themes/
    if not - please provide me login credentials to admin panel, do it ONLY via private message.
  • It is Wordpress.com indeed.
    So the answer is clear.
    There's nothing wrong with our theme or support.
  • Maybe there's nothing wrong. I'll never know since you didn't made clear anywhere it would be impossible for me to install it.
    You say I should know myself your product doesn't work on wordpress.com but I say it would be much nicer of your part to make it clear everywhere instead of waiting a customer to fall on a trap and just after that showing a link and say it's not your fault.
    vilamiu said: Maybe there's nothing wrong.
    No, not maybe. For sure. 100%.
    vilamiu said: You say I should know myself your product doesn't work on wordpress.com
    Not only ours. There no commercial WordPress theme that You can upload by yourself to Wordpress.com server.
    vilamiu said: but I say it would be much nicer of your part to make it clear everywhere instead of waiting a customer to fall on a trap and just after that showing a link and say it's not your fault.
    It's like blaming car company for getting lost in a highway... or in totally new city.
    I don't understand what is so difficult for You to understand.
    I've never seen anything similar to what You expect from us.
    Wordpress.com is your choice, isn't it?
    vilamiu said: ...and say it's not your fault.
    But it's true, it's not our fault. It is simple as that.
  • I only expect a refund, since I cannot use your product. Simple as that.
    But You can, just use it properly.
    And it is You who made mistake.
    And it was You who rated our theme with one star WITHOUT trying it - obviously You did not try it because You can't install it, and You can't install it because You've made a mistake by choosing wordpress.com server.
    Shame on You!
    vilamiu said: I only expect a refund, since I cannot use your product. Simple as that.
    It's not up to us whether You get refund or not.
    And I wouldn't be surprised if You will not get it - your expectations are little bit delusional.
  • Maybe I was not so delusional as you thought - Envato just gave me a refund! XD
    or maybe they just want to get rid of You?
    $49 - this is very cheap for such comfort, I'd give even more...
    anyway - good for You!
