elizabarry.com
That's my site. When I add a post, the page cuts off all the content when there's no featured image and then if there is a featured image, it only shows that and none of the writing/comment parts. What did I toggle?
Also, I want my blog section to look like the sample site with the light navigation. What setting is that? Thank you!
please go to Xpert Options >> Layout >> General, find parameter 'Use accordion effect on content blocks?' and switch it off. It's mora like experimental feature, we still try to improve it, but for now it's working with the most simple websites.
It's been a while, isn't it? The Xpert theme has been improved several times and I highly advice to update it.
As for blog items - do as follows:
1. edit home page
2. find shortocode (element of design) named 'Post Grid' or 'Post Masonry Grid' and EDIT it by pressing pencil icon
3. new window appears with several tabs, find tab 'Item design' and click it
4. pick 'Xpert post layout' from the list
5. press 'save changes' and update Home page
