Hi.
I have a question, I published my website and I have troubles with the tabs and accordion.
It shows only the first tab, and if you want to click on the second, it does not open at all?
Everything entered correct.
The second question. Is there a possibility to add a second Album, which won´t be shown at the Home section?
I want to create something like a Gallery (Sports / Lifestyle...) which are all sub menus under Gallery.
The different sections should showcase the best photos of the different categories with your slider demo.
But I don´t want to see those categories (Sports / Lifestyle...) at the Album section.
Thanks a lot in advance for your help and thanks for that great theme,
Regards, Armin
In album options http://apollo13.eu/docs/thirteen/#!/add_new_album you have option Exclude from Albums list page - you can use it for this.
Thanks for the fast answer.
Here is a link:
http://www.arminwalcher.com/about-me/#1454189449771-20541d14-ce38
Thanks in advance for your help!
Perfect thanks for the Second one!
Best regards
We will also add this fix in next update.
If you click on show previous page (on the back button) a blank page shows up? I updated everything.
All the best,
Armin
Is this issue connected to Tabs issue?
If not, then please start new topic with link to site where that happens.
I'm now having the same problem with the tabs with my site that is using your Chillout theme. The page is http://nextlevelescape.com
Under the 'Our Rooms' section the tabs won't display properly – only the first tab displays, the other two will not turn up when clicked.
Could you please advise how best to fix this?
Regards,
Please start new topic, cause this is different theme, and someone else is supporting Chillout, so he wont be able to find your question here.
