Import Error
Hello i want to ask a quesiton
i want to import data for Hypershot - Photography Portfolio WordPress Theme
but i have error
Warning: set_time_limit() has been disabled for security reasons in /home/janjanlar.com/httpdocs/wp-content/plugins/wordpress-importer/wordpress-importer.php on line 91
Failed to import Media “shattered”
Failed to import Media “logo”
Failed to import Media “adg3com_bustedchump”
Failed to import Media “1”
Failed to import Media “2”
i cant see any media. what can i do ? thanks for your support.
please check this web site http://www.janjanlar.com/ i cant see any picture or media
    It is limitation of some servers.
    I think you have to follow our documentation about importing demo data, and repeat this process until it works: http://apollo13.eu/docs/hypershot/#!/installing_demo_data
  • did you see my error picture ?
    i already did your document. but i cant what can i do else ?
    sizehizmet said: did you see my error picture ?
    Yes I did. It is your server limits, and I can't do anything about it. You can however ask your hosting provider to loosen these settings until you will do your demo data import.
    sizehizmet said: i already did your document. but i cant what can i do else ?
    How many times you have tried? I know sometimes you need 7-10 times.
  • Hello.
    still i have got error "failed import data" i tried about 30 times. i cant import data (www.janjanlar.com)
    can you send me zip files path for the "http://themes.apollo13.eu/hypershot/wp-content/uploads/2012/11" folder.
    may be i can upload manually from the desktop of course if you send me zip path for the pictures "Hypershot - Photography Portfolio WordPress Theme"
    can you zip this folder (http://themes.apollo13.eu/hypershot/wp-content/uploads/2012/11") and share whith me path ? (over we transfer or other ways)
  • edited March 2016 Posts: 4
    and if you want to try for install sample data
    edited March 2016 Posts: 10,970
    sizehizmet said: and if you want to try for install sample data
    You know you have just made your data available for search engine? Never post such data in public topics http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#sending_data
    I have logged to your site and I see you have there some issues with server configuration. Can you move to higher version of PHP, like 5.6? You use now very old 5.3 which is 7 years old and not supported for almost 2 years( https://en.wikipedia.org/wiki/PHP#Release_history ) Also have you asked your hosting provider about increasing max_execution_time setting on your server? You need also more memory for Wordpress.
    As a proof see what is happening when trying to view albums in admin area http://janjanlar.com/wp-admin/edit.php?post_type=album
    Other way is changing hosting to something modern.
    Even if I send you this ZIP data you will face issues cause of these old and weak settings on your hosting. So please first make sure your hosting is prepared :-)
    I will help you as I can with import after this.
