I disabled the page loader and now I noticed an issue.
You can try to go on this page:
http://alexiakaren.ninjacomputing.com/creations/And you will see, as soon as you click on another page in the menu, all the album title are going in the center.
Do you know why this happen?
Cheers
Sure. Such things will happen when you disable preloader but have active AJAX option.
Either disable AjAX http://apollo13.eu/docs/photon/#!/ajax_settings
OR enable preloader even if it would be only dark color without loading animation.
But I don't understand why this issue happen when I leave the page as everything is loaded.
position: absolute
on bricks elements, what moves titles that are positioned in these bricks(also absolute).With kind regards.
It's not possible to disable this behavior? Just keeping the masonry as it is when leaving the page?
position: absolute
to bricks and it should save this situation. But disabling ajax is most advised in your situation, as you don't use music.With kind regards.
I will link it once again http://apollo13.eu/docs/photon/#!/ajax_settings maybe you will open it this time ;-)
In wordpress I can't load only part of theme on "page AJAX reload", cause of very large number of plugins that can mess things around, so I have to load WHOLE page by AJAX and take from it various elements and replace them. So normal full request is done for new page, plus slow JavaScript replacement.
Parts of theme that can benefit from AJAX, like album list, or single album will still use it even if you disable whole page AJAX. It is possible there cause it is part of theme, where plugins can not do much harm.
So just disable AJAX and have happy life :-)
Thanks for you detailed explanation, I appreciate.
