Hello! I have the same issue after successfully used the plugin Duplicator to transfer from localhost to staging server (in a password protected subdomain in the same server as production). The logo shows in the dashboard while configuring the child theme, but it doesn't show on the site (both are in the staging password protected subdomain).
a.logo img {
opacity: 0;
width: 100%;
height: auto;
display: block;
is there any option withing the customize to fix that? or i will use custom css
Please show live link to your site.
This CSS is valid, cause we use it to get good proportion for logo for normal and retina screens.
Any clue on what's going wrong?
Carlos
No clue, I have to test it live to see what is wrong in your case.
If you like you can send me access via private message (click on my nick, in top-right corner you will find option "Message")
In user.css you still have paths like : http://localhost:8080/baga/wp-content/uploads/2016/05/Baga_Design.png
You have to update your setting by changing something in Cutomizer or removing file photon-a13/user/user.css
Thank you for your support.
This means that Duplicator didn't work as advertised.
Best regards.
Carlos
Alistair
