Themes Copy and Paste Options
in Thirteen Posts: 5
How do i copy entire "Meet our team section" from meet our team page and Paste it in the One Page "Latest Photos section"?
Primarily, I want all my content on one page but I really like the meet our team design. I know I could try to recreate the layout but there must be an easier way. Please help!
thanks in advance.
    Hello there:-)
    You can for sure copy source of shortcodes, if you switch from Visual Composer to text editor, and then paste desired row to other page. However this works require some good eyes, to know what are you coping.
    Other way is to use plugin that allows doing same thing by Visual composer interface https://vc.wpbakery.com/addons/clipboard-addon/
    I will ask Daniel to advise some more about this.
    Hello Hubs
    Follow these steps:
    1) Open and copy code from the attached file
    2) Switch the editor to the "Classic Mode"
    3) Past the code on the end existing code and switch back to the "Backed Editor"
    4) Move this ROW using the drag&drop to the place where is "Latest Photo" right now.
    I hope it helps :)
    With Regards
    txt
    txt
    vc.txt
    3K
    Lead Graphic Designer
    Thanks Daniel and Air!
    That really helped. My apologies on the late response. I just have one last question, that I attached images to support. Firstly, how do I get rid of the clickable icons in the top right corner of the site? Primarily the one that opens the about me section on the left side of the theme and the shopping cart?
    Secondly, how do I get rid of the pop out about me section in image 3?
    Lastly, where do I find the social media icons on the bottom left corner of the theme? I want to remove a few and link the rest to URL's.
    thanks in advance!
    348 x 260 - 152K
    404 x 860 - 148K
    545 x 210 - 50K
    Hello there:-)
    In future, please start separate topics for each question about different topic as we ask here: http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#general_rules
    Hubs said: Lastly, where do I find the social media icons on the bottom left corner of the theme? I want to remove a few and link the rest to URL's.
    http://apollo13.eu/docs/thirteen/#!/socials_menu
    See widgets "Hidden sidebar" http://apollo13.eu/docs/thirteen/#!/widgets
    Hubs said: Primarily the one that opens the about me section on the left side of the theme and the shopping cart?
    Removing widgets from "hidden sidebar" will remove one, and deactivating woocommerce will switch off basket.
    Hubs said: My apologies on the late response.
    No worries, we had day off yesterday :-)
    Please read some of documentation, cause you can find there useful info. If you still don't get result for some of your above questions then please start new topics for them.
    Thanks so much team, I really appreciate the help.
