Hi guys i've got a couple of lil'problems with my site www.eventidivertenti.it
First of all i'm not able to make the homepage slideshow looping when it comes to the last picture, it seems that the slideshows ends with a white image that i need to remove and not looping.
Another issue is about the order of the Partners section.
I wanted them in alphabetical order and i putted all the logos in a chronological order to obtain it that but, when i update the page, it doesn't work for the last three logos.
Hope can you help me fixing this problems, many thanks
In the latest version the 'People' shortcode has two new parameters 'Order by' and 'Order way' - with use of them You can easily order items displayed by this shortcode.
When i updated the theme the "classic mode" page edit disappeared and now i can edit the pages only by code.
Finally i wasn't able to fix the slider problem.
Hope can you help me.
1. please provide me login credentials to admin panel - do it only via private message.
2. your website has Visual Composer plugin version 4.9. That's wrong version. Chillout v 1.4.6 is shipped with Visual Composer version 4.11.2.1 - and You should use this one.
Many thanks
