Good Morning,
I have changed the link to one of my photographs on the Page Background image file instead of the one that was used as default.
The correct text is now appearing and if I use the preview function I can also see my photograph.
However, when I type in a deliberate url error to test this I see my text but the originally Photon image.
Is the image coded elsewhere that I can't access?
Thanks,
Alistair
Any cache plugins?
Where exactly have you changed this image?
See settings for 404 error page http://apollo13.eu/docs/photon/#!/pages_menu
There is the Photon function within Jetpack but I have switched this off.
I changed this image on the Error 404 page within Pages by using the upload image function on Page Background image file. This link is what I expect to see: http://www.alistairjamesbell.com/wp/pages/error-404/
In Customise --> Pages Layout --> 404 page template I have set Type = Custom and Select page as your template = Error 404 - The page... (page title) from the dropdown.
Then, if I enter an incorrect URL the result is my text from the error-404 page but the image from somewhere else. Example: http://www.alistairjamesbell.com/wp/pages/xx
Thanks for helping as always.
Alistair
I had already checked this and there was no background image set here.
By adding and then removing my own image it is now appearing as a black background behind the text. Therefore, it is not picking up the pages linked image like the other pages do.
As a workaround, I can set my own image to the backdrop using the path you sent above.
Kind regards,
Alistair
Apollo13 Photon Post Types, Contact Form 7 and Envato WordPress Toolkit.
It seems that is what is causing this particular problem.
With all other plugins active (including Jetpack and all its modules active) except WPML Multilingual CMS the page is displayed correctly.
WPML Multilingual CMS plugin active = page stops working correctly.
The first screenshot is the Java Console information (3 lines only) when WPML = Deactivated.
Second screenshot is the Java Console information (several lines) when WPML = Active.
Hope this helps.
Alistair
I don't know, why WPML is changing these classes, but I know how to fix it on our side. Give me some time, and I will post needed changes here.
I will reply when I will have some news.
Kind regards,
Alistair
I'm not sure if this is related to the same problem (so I'll open a new thread) but the WPML Multilingual CMS plugin stops the search function from working on the whole website.
Thanks for all your reactive support.
Alistair
