Hello You have the latest version of WordPress 4.5.2, so please update Adamant theme to its latest version 1.5.6, which is equipped with Visual Composer compatible with latest WordPress.
please refer to: http://www.apollo13.eu/docs/adamant/#!/installation_update if this will not help than You''l have to perform a manual update, I can help You, but for this I need credentials to login into admin panel and to FTP access. Send me those only via private message.
