Howdy,
At the top of our home page at
http://www.fieldstudiesgrandmanan.com/ I've created a section with a background image and then a table with eight (four on the left, four on the right) thumbnail images that link to blog categories. However, the links are opening in a lightbox. That would be great if it was only the category or post, but it's the full site, with navigation. So, is it possible either to remove the navigation in a scenario like that or, more likely, have the link open the category page without using the lightbox? I cannot find a controller for that. Click the lobster image at
http://www.fieldstudiesgrandmanan.com/ (upper right corner of big hand-drawn map image) to see what I mean.
Thanks,
Simmons
Please add 'block_cb' class to anchor or to image. Whatever You prefer.
