is there an upgrade available, that will allow me to link items in My Works with e-commerce? unfortunately I'm not seeing even an option to add an external ink in this section thanks for any additional info
A) So I need to get Fame and then modify the shop part to look like Chillout ? Unfortunately I dd not find the option to add a button to the Work section - I can add only text and pictures - what should I do to add also the buttons/links?
Krystian said: So I need to get Fame and then modify the shop part to look like Chillout ?
Chillout wasn't tested against compatibility with WooCommerce, You can try thou. But if You need a theme that works well with WooCommerce - check 'Fame' or 'Blame'.
Krystian said: Unfortunately I dd not find the option to add a button to the Work section - I can add only text and pictures - what should I do to add also the buttons/links?
You can enable Visual Composer for Works item and design it with use of this editor.
Krystian said: the Visual Composer has been deactivated
If this request concerns www.doorappgrade.com website then, please update chillout theme up to 1.4.6 version which is compatible with latest WordPress, and is equipped with latest Visual Composer (You'll have to update VC manually)
You can design Work item as You wish - and add a custom button or link in it.
