my site was showing the 4 columns for the products in visual composer and then all of a sudden the columns got split , i'm not sure if its because the plugin needs an update but the screens previous and after should give better insight , i have put the site in maintenance to avoid visitors from commenting
As your page is maintenance mode I can't confirm what happened. However I am almost sure this is effect of some other plugin that you used, that optimizes or compresses scripts/styles. So as we advise please test disabling other plugins first http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#debug_issue
Try adding this file(unzip it first) to fame\woocommerce
It should fix this. If is connected to recent changes in WooCommerce plugin.
However you shouldn't bother, cause this will not be a problem anymore.
When tomorrow update(for theme) will appear, please use it cause it fixes one more issue.
So either if you would or wouldn't write in comments for theme, we would do it in exactly same time.
Wait for tomorrow update, and if it still happen, then please create new topic for this issue.
I had the same problem with my website after the last updates, but even if I downloaded and installed your zip file my situation is still the same.
I've already deactivated all the plugins, but with no result.
Can you help me?
Website is www.italiaamoremio.it.
Gabriele
Have you update theme and WooCommerce to most recent version? Maybe some changes that you did across whole time are messing now(it is possible).
I can try to re-install fame theme, what do you think?
fame\advance\utilities
- it will fix it.Don't worry same change will be in next update.
Thanks for reporting this!
Gabriele
Thanks for coffee!
http://www.kissthedesign.ch/categorie-produit/design-vintage/sieges-vintage/
I'm working with a child theme.
Any clue?
Many thanks in advance for your help :-)
Best
PS: I have the woo commerce customizer but the changes dont work
Maybe you can find the code that make the columns issue.
it won't help for the broken Visual Composer though..
many thanks for your help.
Best
Also I did some tests and it's sure that woo commerce did break Visual Composer.. :-(
Sorry but we don't fix issues caused by your modification http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#support_not_includes
Use tools to compare files like WinMerge to see what should be changed in content-product.php to have your changes and also what is esential for proper work. This topic might help in removing things from your version https://wordpress.org/support/topic/26-update-product-column-display-is-wrongwrong-number-of-products-shown
You should remove all modification that interferes with proper work of your site, and then gradually add them step by step to find what should be changed/removed/fixed.
As for Visual Composer - make sure you installed latest version of it with Theme update (VC 4.12) and after it inserting shortcode for product on your new page, to see if it will fix it. Best would be also to start separate topic for this case.
Best
