I've a issue to fix. When I insert recaptcha field in my CF7 form appear a text field under recaptcha button in frontend. Is there anyone that can help me please? Thank you
Hello, please try using Xpert theme with 'Use accordion effect on content blocks?' option disabled. Please go to Xpert Options >> General and set 'Use accordion effect on content blocks?' option to 'no'. If the problem will not vanish - please provide me login credentials to admin panel. Do it only via private message.
It's ok as display on website! thank you PS: now, however, if you forget to check it before you send the message, it doesn't advise you to check before send a message...
please go to Xpert Options >> Custom Style and paste this definition
