Row ID missing in vc_row template
edited July 2016 in Blame Posts: 1
Hi there,
First of all, great theme and great job.
I have found a small issue in the newest version of Blame theme. The vc_row template located in vc_templates directory is missing $el_id section so no Row ID's are rendered on the page.
To fix this issue it is necessary to:
1) add the following snippet in vc_templates/vc_row.php in line 45:
if ( strlen( $el_id ) ) {
$html_id = 'id="' . esc_attr( $el_id ) . '"';
2) and replace the line:
$output .= '<div class="a13_row_container'.esc_attr($block_classes).'"'.$data_attr.$style.'>';
with
$output .= '<div class="a13_row_container'.esc_attr($block_classes).'"'.$data_attr.$style.' '.$html_id.'>';
Thanks,
Przemek
