I just purchased this theme, i checked the videos "Installation and basic setup" which all the steps worked fine but now i'd like to upload the demo data file so i can have a website pretty much built up (with all the different options of headers, shop sections, etc...)but I keep getting the error 404 and when i go to appearance -> menus, the "MainMenu" i'm supposed to select with all the pages (as shown in your demo data file import video) is not there.
Same for the woocommerce dummy file, it tells me some elements fail the import and I have tried several times in case it was the server struggling.
What can be done?
Thanks for your time.
Regards.
Have you tried our one click demo data import? It makes all process for you, check it http://apollo13.eu/docs/fame/#!/installing_demo_data
If it won't help then I will take a look on your site.
Thanks for your reply. I tried that method and also tried a plugin called One Click Demo Import as it didn't work with the first option but still gives me an error 404.
I would really appreciate if you don't mind having a look and see if you can get the demo file uploaded, i have sent you in private the details you can use to log in my account.
Let me know how you go.
Thank you
Server was throwing random 404's while importing cause it had low some settings in PHP config. After changing them it wen smooth. See below image for reference
In this case I believe you can have low one setting in your PHP. See this section form our other theme documentation http://apollo13.eu/docs/fatmoon/#!/issues_importing_demo_data and see if you can do anything and if it will help. If not I will try other way to help you.
Sorry once again for my confusion earlier.
