I won't be using anything else in the header - is it possible to comment the other icons out in the header.php file or elsewhere -- thus opening up space for the full menu at the top ?
Then we will have to switch to not compressed version and mess around with code. Firstly we will deal with your IE 8 issue, then we will try fighting here.
Edit: Link to your project will help a lot with doing it.
Hmmm i just have checked your site and in narrow view(I don't have Ipad) menu is fully wide. It is strange, but it works now for me. I will et some simulator and try to check again, but mean while please confirm that it doesn't work on iPad.
I experimented with editing the CSS through trial and error so can't exactly say what was taken out. It is still not ideal as best case scenario is that Logo + Menu Items should all be on the same line assuming there is sufficient space. Currently it is split unnecessarily over 2 lines with the logo occupying its own line and then the menu items underneath.
I must tell you that such targeting only one device with your changes is nor future friendly nor user friendly. But OK, if you want it for yourself:-) To make menu in one line with logo for Ipad, I think we should lower font size there and remove some lines like this ~2243
Any suggestions ?
menu bar should ideally be all on 1 line
Description thing - it is long description there so it may not fit.
Hmm dunno what to do with that now...
Compatibility with the ipad is obviously so important now-a-days.
I really appreciate your help.
I have sent you a PM with the live project details.
Many thanks
Don't worry we will make it better for you :-) But first IE 8 topic!
#access, good, but you could let me know, cause I am wasting time looking for differences.With regards.
