Tile color change with img
in CeeVee Posts: 11
Hello. is it possible to set "Tile image" instead "Tile Color?
For example use attached "Background tile" , then onmouse see another image?
Thank you very much for help.
    Hello!
    If you place this image as 'Tile underlying image' and change 'Tile color' and 'Tile hover color' to the same (transparent) value - then, I think, you'll achieve what you want.
    Already tried, (when I set Alpha 1% on both colors) it displaying just Tile overlying image :/
    Tried to change "a13_tile_color" in A13_extra_params.php .. but nothing happens :/ (when I add color manually its working, but there is problem with pic :(
    vaclik said: Tried to change "a13_tile_color" in A13_extra_params.php
    It's better not to modify our plugins, you will loose it with next update.
    As for the issue: when you edit row settings and define transparent colors - you can make them completely transparent. There's a text input there - set the last parameter of rgba color definition to '0'.
    If 'Tile overlying image' is covering 'Tile underlying image' - remove the 'Tile overlying image'.
    692 x 678 - 125K
    Yes I already tried to set Tile color - "rgba(255,255,255,0)" and Leading color - rgba(255,255,255,0) , then set Tile underlying image ,but doesnt have option to add second image onhover. I think it must be able to set Tile color as image thats what Im trying to do :-)
    Ok, now I get it.
    There's no option for separate image on-hover. sorry :(
    Oki, no problem. I will try to find out on my own :) Anyway thanks for your Time and your great template . Great Regards from Czech republic ;)
