Visual Composer not working
Suddenly my visual composer stopped working, I guess after I made the update to the newer version of wordpress. What can I do?
Thank you
Rob
    I think that you don't have the latest Chillout version.
    Version 1.4.6 is compatible with latest WordPress.
  • edited September 2016 Posts: 3
    Okay, I did, I uploaded the new version, updated all plugins but I can't update 'WPBakery Visual Composer', it says Installed version: 4.5.1, Minimum required version and Available version: : 4.11.2.1 . Trying to click on 'uodate' but nothing is happening. Where is the problem?
    CheerS
    Post edited by roblondon on
    So you must delete the old one it manually via FTP.
    navigate to wp-content/plugins and delete js_composer folder, then go bact to admin panel and install new one in the same way as you tried before.
  • I tried to delete but then I can't go back to the admin panel. I can see just the white screen
    The plugin package is located in '..\wp-content\themes\chillout\inc\plugins' and its name is 'js_composer.zip.
    Unpack it and copy via FTP to 'wp-content/plugins' folder
  • Thank you! This solved my problem!
  • Hello, can you email me the updated template as well. I am having issues updating via Visual Composer. Thank you. roland@8pointmarketing.com
    Hello Roland
    Check your inbox.
    Best Regards
    Lead Graphic Designer
