Hi Air,
I'm having a trouble with the logo, when I navigate on any pages of my website the logo start to appear 1-2 seconds in small and then in the size I'v defined in the css as indicated in Fame's doc (.highresdisplay), same by refreshing the page. So that the navigating is kind of "jumpy". Any idea how I could correct this issue?
Here the website:
http://www.kissthedesign.ch/Thanks in advance for your help :-)
I tested it on FireFox and didn't experience anything like that. On what device/browser you see it?
Experiment some with both those things.
As for CSS - remove it for now.
I'v removed the CSS now.
Many thanks for your help :-)
Anyway for now do such things:
1. Disable WPML.
2. Go to fame\wpml-config.xml line ~28 and remove following lines: 3. Re enable WPML.
4. Now you should be able to make all logo changes by theme settings.
