Dear Apollo 13,
I'm sorry to not find any solution to my problem by myself...
My website use to work until a WP update (and maybe plugins)...
I believe that the website cannot connect the scripts because chrome (F12) find this error :
"Failed to load resource: the server responded with a status of 404 (Not Found)"
Can you help me to fix the problem ?? My website is :
http://arnoweil.fr/Another bug less serious : the sub item in my menu now don't open down but left and without background.
NB: Ajax is already shutdown
Many thanks,
a
You have to update theme, as you have pretty old version which is not compatible with newest WordPress versions.
http://apollo13.eu/docs/photon/#!/installation_update_update_theme
Thank you for answering !
I updated the theme and I am now with Version : 1.2.7 (and wordpress is 4.6.1)
For some reason, homepage is working again but the other pages don't.
Can you please help me ?
I have no idea yet what is exactly going on, but start with plugins please.
Thanks again for your help.
Last bug since these updates : can you tell me why my sub-item "P&L" in the main (and only) menu under item "private" opens left and not down like it used to do...
best regards,
ps : there is now in the slider view a command in the top (with number, zoom, player, download and close buttons) may I disable this bar and the title bar in the bottom ?
Is there a documentation about all the available CSS customization ? (more explicit that http://apollo13.eu/docs/photon/#!/custom_css_menu ?)
For example I would like to let title (+ legend) appears when mouse over the pictures in the lightbox or in the bricks albums... But I don't how for the "legends" field (sorry my WP is in French) and I would like to have a small font and a background behind... I can open a new topic may be ? :-)
Start new topic, add link & screenshot of what you need, like explained here http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#modification_rules
