Homepage Menu Icon not found
edited October 2016 in Fame Posts: 6
I installed fame theme and ı maked new custom homepage.But I want put fa-home icon near the homepage.I can't found.I choose homepage inside menu icon (fa-home) but I can't see.Could you help me pls? How can solve this problem? Thanks
    Could you post link to your site?
    Do you have any cache plugins installed?
  • edited October 2016 Posts: 6
    Hello :)
    I don't use cache plugins.
    website www.hdrtextile.com/
    I am off today.
    However I only asked for address of site, not login data. I have removed data your provided as anyone could login.
    See http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#sending_data
    I will check tomorrow your issue.
  • I'm so sorry.I am waiting your reply.Thanks for everything
    Now I see what was the problem. You should select icon from icon selector that would add only home NOT fa-home as fa- is added later in code:-)
    You are good to go now!
