I purchased the Airborn theme yesterday and trying everything a bit now.
The portfolio slider isnt working. It does not change the image and the button below to choose between the different items are all selected (filled). If I press on one of the buttons it just sends me back home.
You can see my test installation here with the slider on these two pages:
http://prisma.q-nox.de/test/http://prisma.q-nox.de/How can I fix that?
Second question is, where do I find the configuration to change the height of nivo and piecemaker sliders?
Thanks for the help
Flo
Thanks for link to live project.
About slider I see, that you have some jquery conflict, and that pointed out bug in airborn theme. We will sort this out ASAP and release update.
About configuration, you can find it :
nivo wp-content/themes/airborn/common/cssnivo-slider.css line 18
piecemaker - not now (you can dig in airborn/user/*.xml files) :-)
But even if you change height it wont take any effect, cause of fixed image sizes in Airborn theme(it may do something if you set lower height). We will try to tweak it also.
Sorry for any inconvenience and please stay tuned.
Maybe this information helps you for fixing:
I have these two plugins installed: "Transposh Translation Filter" and "WP UI - Tabs, accordions and more."
I installed the second one, because otherweise the jquery-ui is missing and the box-designs of transposh dont work.
How ever after I deactivated the two plugins the slider still didnt worked.
I will post info here when fix will be available. Thanks again for all help :-)
I did some customization to the nivo slider so that the images could be linked now same as in the in piecemaker slider.
in shortcodes-generate.php i did add near
array(
'id' => 'sliders',
'name' => __( 'Sliders', TPL_SLUG ),
'codes' => array(
array(
'name' => __( 'Link to', TPL_SLUG ),
'subtag' => 'slide',
'id' => 'url',
'default' => '',
'place' => 'attr',
'type' => 'input',
'additive' => true
and in sliders.php i did add around the img tag:
if( isset( $matches[1][$i]['url'] ) && trim($matches[1][$i]['url']) != '' ){
$img .= '';
$img .= '';
maybe thats usefull for others as well.
about the image size i did see that ne nivu slider just takes the height of the image if i use a longer one, so thats fine for me. i can just use the size that i want for the images there.
can see it with my linking change here: http://prisma.q-nox.de/beispiel-seite/
$img .= '< a href="' . $matches[1][$i]['url'] . '" >';
$img .= '< /a >';
We will use your info. Thanks for all support once again ;-)
