Hi guys
I'm trying to get rid of the navigation arrows that show up when hovering on the top panel in the single work section, and also the animated Pause graphic. Can anybody point me in the right spot in the Css and what to change there?
Please see link of page I mean.
http://www.baxterstudios.com.au/dev/FB/work/my-great-big-adventure/thanks!
I have been on your site, but it appears that you managed to disable these controls, right?
I think I will have to fix slider to don't display controls when only one item is in. Thanks for clue!
I would just put a rev slider up there but if I leave the featured section blank and don't upload an image, the whole page breaks and just shows me a blank page...
thanks!
Update will be ready on Monday, so then you should update:-) If you don't plan to use slider for now then disable Media: Work Media -> Present media in -> Do not display I see that you have added
opacity:0;to arrows and they are hidden all the time.With kind regards.
On a different subject, where can I slow down the appearance of the content of the tabs in the TOUR widget?
You should start topic for different cases, as it doesn't relate to original issue.
However, I think there are no additional settings for this element from Visual Composer.
