Blog post header image tiling
If I upload an image that's too small for a blog post, the image tiles (lots of the same image side by side in header). Is there any way to stop this and just have the single image? We can't always upload big images/the correct resolution for blog posts. Screen shot attached.
    Could you please provide url of your website now? Is it ready?
    Hello there:-)
    In options for title bar for blog, in option "How to fit background image" set "just center". It should do the trick.
  • edited December 2016 Posts: 70
    Never mind. I had to click "use custom settings" Silly mistake haha.
    Thanks guys :)
    Post edited by designdogs on
