I have added "Single Image" widgets to my page. The size of each image in the widget is explicitly set to 200x300. The actual size of the image is the same. Please see the attachment.
But when the page renders, the images become 240x360. Do you know how to make it render with the specified size?
You can also see the page at
http://sambotactical.com/instructors/Thank you!
I see only that the last image is in the different size [screen shot removed]
So there should be something wrong with the settings with the last image.
Please compare settings of this "Single Image" shortcode with the first and the second one and try to find what is wrong because i cant say what is wrong with only your screenshot from the panel.
With Regards
But please, remove the screenshot you posted.
Thank you!
Thank you!
I see your page is displaying images exactly as you wanted, so it seem that case is closed, right?
