Logo problems
in FatMoon Posts: 16
I have a problem with the logo.
It is displayed in preview mode, but when the website is live it disappears completely in some browsers.
It also does not appear in mobile browsers.
Www.guilhermevignini.com.br/daiane
    Your path to logo image is http://localhost/daiane/wp-content/uploads/2017/01/logo_brc-1.png so you have to update it.
    You are currently using light variant header so you will have to change your logo in
    Customizing ▸ Header settings ▸ Variant light - overwrites ▸ Logo image
    Read more:
    http://apollo13.eu/docs/apollo13_framework_theme/#!/header_variant_light_dark
    If you want to have exact same logo in every color variant of header and in sticky header
    check option:
    Customizing ▸ Header settings ▸ Logo ▸Use logos from header variants
    Hello
    I did what you suggested. I re-uploaded the logo again. I changed each logo in the settings, but it still does not appear on desktop or mobile.
    For some reason your logos still have such url http://localhost/daiane/wp-content/uploads/2017/01/logo_brc2-1.png when you check in user.css file.
    Do you have any cache plugin installed? It may be source of issue.
    No. I don't have any cache plugin :-(
    Weird that all the modifications I make are updated, except the logo.
    edited January 2017 Posts: 10,970
    You have this type of server where you have to give FTP credentials for every save action that happens on files. Unfortunately when you are in customizer you can't see this form so you can enter password so user.css file would recreate.
    I will work on something that will show up this form when you leave customizer or option that will embed source of user/user.css file into body of page for such servers. But that is for future.
    Anyway it would be good to ask your hosting provider to change something so WordPress could write to its own files, cause now it can't.
    Try logging to your WordPress now, and then when you will be asked for FTP credentials give your data. Next check if user/user.css file was created, cause now I have removed it.
    Thank you, I did what you suggested and I managed to upload the logo, logging in and logging out.
    Thank you for your support.
    Oops, I checked the logo and it still does not appear on the mobile. Is there anything that can be done?
    Try refreshing cache on your phone as it works for me and logo is displayed just fine :-)
