error var a13_no_ajax_pages
edited February 2017 in Thirteen Posts: 45
Hello, since a update, I have a problem with my english version with polylang. We can read this error :
var a13_no_ajax_pages = []
_stq = window._stq || []; _stq.push([ 'view', {v:'ext',j:'1:4.5',blog:'114787437',post:'1184',tz:'1',srv:'lucaskozak.com'} ]); _stq.push([ 'clickTrackerInit', '114787437', '1184' ]);"
on this page : http://lucaskozak.com/en/home/
And when polylang is off, a problem of display is showed.
It's just a problem with Wordpress 4.7.2 or not ? Thanks.
Post edited by Onypsis on
    Onypsis said: since a update,
    Since update of what? I assume that you mean WordPress, right?
    Where do you see this problem, cause I checked console on Chrome and Firefox and I can't see it.
  • Wordpress, yes.
    1366 x 768 - 194K
    Then it must show only for logged in user, cause I don't see it. Can you verify?
  • I am not logged in admin, just a simply visitor. It's strange.
    Recently, I have installed WP Super Cache extension.
    A bug is present also with this page : http://lucaskozak.com/en/resume/
    1268 x 713 - 275K
    Onypsis said: Recently, I have installed WP Super Cache extension.
    Please clear its cache and deactivate it next.
    We still see different things strangely.
  • Extension clear and desactivate now.
  • The error's message is now :
    (function() { var request, b = document.body, c = 'className', cs = 'customize-support', rcs = new RegExp('(^|\\s+)(no-)?'+cs+'(\\s+|$)'); request = true; b[c] = b[c].replace( rcs, ' ' ); // The customizer requires postMessage and CORS (if the site is cross domain) b[c] += ( window.postMessage && request ? ' ' : ' no-' ) + cs; }());
    OK I can see now error.
    It looks that AJAX is broken by something, try turning it off http://apollo13.eu/docs/thirteen/#!/ajax_settings
  • I have desactived Ajax.
  • The message is not present, but the problems of display are again here.
    Your text widget in header area has broken HTML and this is why you got all those problems :-) You must have there unclosed DIV or something.
  • Thanks !! :D
