I am using Hypershot and the full width slider for the homepage. I would like to remove the pattern that shows up over the images, or reverse it so that the primary image does not have the pattern but the other images do. If you go to my site you will see that it opens up with an image that has the pattern over it but the images on either side of it do not, until you hover over it or select it. I would like it to be reversed so that the image that is being featured does not have the pattern but the images to either side do have the pattern, until they are hovered over or selected. Here is the link to my site:
http://taguephoto.comI saw a similar post which you provided css for, but they were using the bricks version. Thank you for your help!
Steve
Even if you had there slider before, then what the use of having pattern on images that are not visible(only one image is visible at once in slider)? Then they would have patter only for time where the animation happens.
I don't think I understand idea in case of slider. So if you can please explain ;-)
Try add such custom CSS: With kind regards.
