Hi, I changed the slug on the works page to portfolio, which seemed to work out ok, but in doing so, I have a constant error message on the admin page of the site that says that it could cause issues. Is there somewhere in the theme I can change this to Portfolio?
I saw on a separate post this was possible in the Chillout theme, so wondered if you used the same type of setting for the Fatmoon one.
Thanks in advance
You should have unique slugs. However if you don't see any 404 errors while going to your single works, then you should be fine and you can ignore it.
