Hi Apollo,
We have an Events calender installed on our website, which uses a "Feature Image". When this image is clicked it opens the lightbox feature of the theme (Displays as black box). I would prefer that the image links to a page instead?
Is there a setting I can change to ensure that the image does not open in the lightbox, but instead links to the page instead.
http://tinyurl.com/j3rnu7aThanks,
Mandy
if you add 'block_cb' class to image or anchor - it will prevent opening lightbox.
Thanks for your suggestion. I've tried a few things, but I am struggling to see where I can apply the 'block_cb' class to image or anchor.
Please are you able to advise where I might find the code for this?
Thanks,
Mandy
Credentials send via private message, please.
