Hello apollo13,
I can not activate the section of the portfolio. I've tried a thousand ways and this is impossible.
You can see it here
http://www.artcreative.es. If you want, I can give you access to the control panel.
Another question, how can I activate the contact form?
You say you tried thousand ways, but could you write few of them, so I will not loose time for writing things you have already done ? ;-)
Did you check documentation( you should have it in package form Theme forest)? If not please scan it, mainly http://apollo13.eu/docs/airlock/#!/adding_portfolio and http://apollo13.eu/docs/airlock/#!/airlock_portfolio_settings
For contact form:
1. Add new page
2. Choose form templates menu 'Contact'
3. Save & Done
If you have problems use demo data, also described in documentation http://apollo13.eu/docs/airlock/#!/demo_data_images_sizes_and_others
I have a new problem now; I created two portfolios, but these are not published, in the home or in the portfolio section. I followed the manual, thinking that might be a dismissal as the previous, but can not find anything.
Thanks for your help!
Did you added them to any category?
I've uploaded your data and now appear items, but I do not know why after uploading your data file the site lost the item rollover effect on home page
Cause of images in posts don't load, javascript breaks on images that it can't convert to grayscale(cause they are not loaded). Delete posts with images that can't load(or add proper paths for images) and it will get back to normal. Scripts that operate on images can have difficulties when operating on images that are placed on different server.
