I wanna ask about the mobile video player, On IOS devices its working perfect but on Android phones you cant see the players controller to play/pause , changing volume or maximizing.
Try going to full screen mode in lightbox and then click on video. I will test it tomorrow when I will get my phone back, so I could see what could be interfering.
It maybe be related to hijacking some touch events by lightbox on Android. It wont be easy to debug nor to fix. I need some time, so I will reply when I am done with it.
Nope, didn't had time yet. It has pretty low priority in things that have to be done, and I am alone at the moment for such tasks. Like I said I will reply when I will have info for you.
http://imgur.com/a/QzJhi
my only option is to slide the video and move on to another video.
So we have to check how it can work on normal mode.
Waiting for your test thank you very much
I have just tested this again on main demo of lightbox http://sachinchoolur.github.io/lightGallery/demos/html5-videos.html and it also doesn't work there.
For me it doesn't work either on iOS and Android. Could you verify this?
I f you confirm it then we will have to inform lightbox author about it.
I will have to report it to plugin author, as there is no much I can do with it from theme level.
