Thank you for your help. I feel like I'm having a simple problem with my site -
The album bricks on my main album page ("work") are no longer responsive.
They used to stretch (and/or rearrange) to match the width of the browser. Now, they just stack to the left and do not respond outward (to fill the page).
If I scale the browser down to smaller than the bricks, they only scale by column, not all together (as uniform sizes).
This appears to have only happened after I tried adding margins (more than 0px) to the bricks. I returned the value to 0px, but the problem remains.
Here is my website: www.ojmiller.com
Attached is an image of the problem.
Do you have an idea what may be the problem?
Try going to Customizing ▸ Albums Layout ▸ Albums list appearance ▸ Brick margin and make sure that there is value 0px. This
pxat end is what is important.With kind regards.
Thanks for getting back to me! Yes, the value is 0px exactly. Unfortunately I still have the issue
Next set it to 0px with slider, Save, check does it work.
Problem is with generated CSS that it has only '0' instead of '0px'.
If none will help, try updating theme, cause there is a chance there was a bug in older version, that I have fixed already :-)
