Hello, I have created a page with pictures (not an album), and like the display is classsical, the result is here :
https://lucaskozak.com/projets/nancy/I will know if it's possible to kept the format page and to choose the display, horizontal or vertical ? Or if the page is necessary in vertical ?
Thanks.
You mean you want to display each image beside previous image? If yes, then such layout are only possible when it is specially prepared, with some custom code. Natural flow of webpages is vertical, and this is how content will try to fit on page.
With kind regards
