A page with pictures in horizontal ?
in Thirteen Posts: 45
Hello, I have created a page with pictures (not an album), and like the display is classsical, the result is here : https://lucaskozak.com/projets/nancy/
I will know if it's possible to kept the format page and to choose the display, horizontal or vertical ? Or if the page is necessary in vertical ?
Thanks.
    You mean you want to display each image beside previous image? If yes, then such layout are only possible when it is specially prepared, with some custom code. Natural flow of webpages is vertical, and this is how content will try to fit on page.
    Yes, it's to separed my projects (display the images in vertical) and my series in horizontal if it's possible.
    Nope, it is not possible. We had such scroller script in our previous themes http://bp.apollo13.kinsta.com/work/posters-pack-ii/ but not in Thirteen.
    With kind regards
    Alright, I have a last question, it' s just possible to hide this information on my albums ? (the number of pictures) Thanks :smile:
    1031 x 594 - 755K
    Sure:-) Use this custom CSS:
    span.slides-count {
    display: none;
    Thanks ! :smile:
    And for the logo of play juste at left ? and on the picture when I click for the autoplay ? If never I will need to hide this. Thank you !
    Can you rewrite your question, cause I don't know what you ask about, sorry. It would be better to start new topic for different cases, cause current question are not connected:-)
