Can you tell me please where can i translate : next and previous which are on the page WORK (to move to the next project) ? I would like also change the name work. Thanks you, Edwige
Edwige said: I would like also change the name work
Please explain or show on screen shot what do you mean.
Edwige said: Can you tell me please where can i translate : next and previous
You can do it translation file http://apollo13.eu/docs/apollo13_framework_theme/ or in code if you need : \fatmoon\advance\utilities\cpt_work.php line ~144 there you will find strings 2 x 'Previous' and 2 x 'Next'.
Hello Air, Thanks for your help but i change Next and Previous on the both zone. But it doesn't work. "I see that Parse error: syntax error, unexpected T_STRING in /home/websitename/www/wp-content/themes/fatmoon/advance/utilities/cpt_work.php on line 148"
You can do it either in translation file or in code, your choice :-)
Code screen shot of places to change
Can you help me please?
or other character that is part of string you wanted to change.If you still are not sure what exactly is wrong then post me screen shot of that part of code.
