Hey Folks!
During March of 2020, and possibly April, answers may be delayed more than it usually happens. This is caused by my personal situation that requires a lot of time from me to be dedicated elsewhere, and also because of the local things that are happening currently cause of the all things connected to "Corona Virus".
Please be patient, all answers are coming as soon as possible, even if I have to stay late at night :-)
Sorry for any inconvenience.
Air.
Bold text in revolution slider makes the font smaller...
Hi there,
I have this strange issue with the revolution slider of my website. I have put some text in bold by using and , but now the text appears in bold, but has a smaller font... How can I make sure that the font of the non-bold text is the same as the bold text? On a computer screen it isn't that visible, but on mobile, it's definitly visible.
Thx for helping me out! (again ;-)
Anneleen
PS: the website is www.deprojectarchitect.be if you would like to check it out.
    Hello Anneleen
    I'm not sure if you know this ;) but you must change the fonts and other elements on different resolutions: http://nimb.ws/TOml2N
    With Regards
    Lead Graphic Designer
  • Hi there, yes I know :)
    That's not the issue. The font looks ok in the revolution slider. No difference in font-size, but when I check the website, or the mobile versions, only the bold text looks smaller for no reason. It's a strange thing... Is it possible to set the text bold without using the code? It probably is behaving different because I use this instead of the regular bold-setting? But I can't find it under 'style'...
  • edited November 2017 Posts: 399
    Hello again
    Now I see the problem (to be honest I didn't know what you meant at first ;) ).
    Yes, you can't use the option to bold these texts because such options do not exist :)
    Try to use "strong" instead of "b". It looks like some other styles try to rewrite your style.
    Let me know if it works.
    With Regards
    Post edited by Daniel on
  • Hi Daniel,
    No unfortunately still not working. I used 'strong' instead of bold, but still the same outcome...
    Hello again Anneleen
    It looks like the Revo Slider issue. I can try to find solution here in comments but it will look like ping pong because im not sute what cause the problem ;)
    With Regards
    Hello Anneleen
    I spent on this case more than an hour and to be honest I didn't find what is causing the bug. I fixed this by adding font-size:16px to the strong tag.
    With Regards
  • Hi Daniel,
    Thank you so much! It's a strange thing. Happy you could solve it :)
    Anneleen
