Hi there,
I have this strange issue with the revolution slider of my website. I have put some text in bold by using and , but now the text appears in bold, but has a smaller font... How can I make sure that the font of the non-bold text is the same as the bold text? On a computer screen it isn't that visible, but on mobile, it's definitly visible.
Thx for helping me out! (again ;-)
Anneleen
PS: the website is www.deprojectarchitect.be if you would like to check it out.
I'm not sure if you know this but you must change the fonts and other elements on different resolutions: http://nimb.ws/TOml2N
With Regards
That's not the issue. The font looks ok in the revolution slider. No difference in font-size, but when I check the website, or the mobile versions, only the bold text looks smaller for no reason. It's a strange thing... Is it possible to set the text bold without using the code? It probably is behaving different because I use this instead of the regular bold-setting? But I can't find it under 'style'...
Now I see the problem (to be honest I didn't know what you meant at first ).
Yes, you can't use the option to bold these texts because such options do not exist
Try to use "strong" instead of "b". It looks like some other styles try to rewrite your style.
Let me know if it works.
With Regards
No unfortunately still not working. I used 'strong' instead of bold, but still the same outcome...
It looks like the Revo Slider issue. I can try to find solution here in comments but it will look like ping pong because im not sute what cause the problem
With Regards
I spent on this case more than an hour and to be honest I didn't find what is causing the bug. I fixed this by adding font-size:16px to the strong tag.
With Regards
Thank you so much! It's a strange thing. Happy you could solve it
Anneleen
