Hi support team,
I am using a separate team plugin and this works perfect together with your theme. But if I put the team carousel as a widget in the third column (as shows on my website fotografie.io) the title "Fotografen" will be generated to the next (fourth) column. I tried it with the text and the shortcode widget - not differences. It would be great if someone has an idea to solve this issue.
Kind regards, harald
It looks that this shortcode is badly created, and it outputs its code too early, and cause of it braking footer layout.
Hard to tell exactly but looks like it is not appropriate for widgets.
What plugin are you using exactly?
Kind regards, Harald
Thanks in advanced, harald
PS. If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate? http://fc07.deviantart.net/fs71/i/2012/038/8/5/how_to_rate_a_file_template_by_cooledition-d4oxno5.jpg
Hope developer helped you in fixing issue with his plugin!
Listen, send me temporary FTP access by private message, and I will fix it. Then I will write here exactly what I have changed.
Add this custom CSS to fix styling: For some reason author of this plugin added class
.widget
to this module, that breaks look. It shouldn't be there.I have edited file /plugins/iam_team_showcase/includes/iam_team_showcase_shortcode.php and just added at begging of function:
ob_start();
and at end to make sure that none of a code output leaks too fast.
