The only thing I did differently was call and ask A2 Hosting to add memory up to 128 in an attempt to fix the template library not showing up. They did this and then I could not access the Elementor interface. Then I called them back to ask if something might have happened in that process of increasing the memory and they checked everything and said no.
Please try debug issue instructions https://support.apollo13.eu/discussion/12/before-you-ask-read-this?new=1#debug_issue and be sure to test it also on default WordPress theme.
Have you tried debug method that I asked you in previous post?
Destination folder already exists. /home/seedpods/public_html/wp-content/plugins/js_composer/
Plugin installation failed.
Plugin not activated. A higher version of WPBakery Page Builder is needed for this theme. Please update the plugin.
There is no higher version than the one I am trying to install.
