Trying to figure out what the Top bar options do.
I am using the default demo with header, then turned on the top bar. Tried changing text/link/hover color, but they don't do anything.
Tried to change "Social icons" color to white or black or semi-transparent, but they stay in color.
"Message part" and "Message text" don't appear to show up or change, I can't see them having an effect on the top bar.
Image:
https://imgur.com/a/DNudYTried on: Windows/Chrome, iPhone/Safari
Documentation:
"Header - Top Bar
It is for horizontal header only!
Here you can set upper part of header. You can set almost every color of it here. Also you can choose to use Message or Use menu from Alternative short top bar menu position.
This is also part that we choose for Language switcher if you use WPML plugin."
Top bar is additional "bar" for header. Example use of this you can see in one of FatMoon demos: http://rifetheme.com/fatmoon-rotterdam/ - part with phone & mail in theme header.
On your site I see you use vertical header currently, so it will not show any difference.
Preview in customizer may lie to you cause of Redux Framework bug http://rifetheme.com/apollo13-framework/docs/getting-started/known-bugs/changes-disappear-while-in-customizer/
I am currently working on removing dependency on this plugin from all our themes, so it will be released in version 1.7.
Yes, whenever I test with the Top Bar I use the horizontal header only; it wouldn't make any difference in vertical header!
Looking forward to trying out the changes when 1.7 is released.
(Photo 1) I turn on the Top Bar, then try to get the text to change color
The text stays black, on a black bar. I assume the "Background color" controls the bar background color, but it doesn't change away from Black (for this example I tried to make it red). Both the Bar and the Text are still black
(Photo 2) I open the site after Publishing changes, in a different browser too. Shows black bar with black text
https://imgur.com/a/mJhOZ
Look there for Top bar - Background color & Top bar - Text color. These options will only be visible if Top bar is activated.
Read more here http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
To edit social icons links check this out http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/social-settings/
As for questions- it is better to start new topic for your case http://rifetheme.com/apollo13-framework/docs/getting-started/support-forum/creating-new-topic/
