I just added an SSL certificate to my website but now the Vimeo links are no longer working. I'm disabling my certificate now so that they will work in the meantime, but what should I do to fix this?
However probably this is not solution you are looking for;-)
I have found 2 instance of Vimeo links in theme.
You will just have to change them to be more universal.
Go to hypershot\js\album-view-full.js line ~1095 and change tag.src = "http://a.vimeocdn.com/js/froogaloop2.min.js"; to tag.src = "https://secure-a.vimeocdn.com/js/froogaloop2.min.js";
Next go to hypershot\advance\utilities.php line ~908 and change return 'http://player.vimeo.com/video/'.$v_id.'?api=1&title=1&loop=0'; to return 'https://player.vimeo.com/video/'.$v_id.'?api=1&title=1&loop=0';
In case of on link in hypershot\js\album-view-full.js line ~1095 I was wrong. I have now edited my answer. It should be tag.src = "https://secure-a.vimeocdn.com/js/froogaloop2.min.js";
One solution would be to change theme, as Hypershot is no longer supported.
If you are interested then read this https://apollo13themes.com/move-to-new-theme/
and change
tag.src = "http://a.vimeocdn.com/js/froogaloop2.min.js";to
tag.src = "https://secure-a.vimeocdn.com/js/froogaloop2.min.js";Next go to hypershot\advance\utilities.php line ~908
and change
return 'http://player.vimeo.com/video/'.$v_id.'?api=1&title=1&loop=0';to
return 'https://player.vimeo.com/video/'.$v_id.'?api=1&title=1&loop=0';With kind regards.
tag.src = "https://secure-a.vimeocdn.com/js/froogaloop2.min.js";Then it will work.
