I have uploaded the Fatmoon theme via ftp. I can see the full theme files in the back end, but not in WP. So I cannot customise my theme fully. Please advise me as to how I can see these options. I currently only see 6 customisation options. And I know there should be about 14 options. Do I need to activate the theme before I can see those options? I was hoping to edit the new theme offline first before setting it live...
First thing first - you will find this useful https://www.take-a-screenshot.org/
Next have you activated bundled plugins? http://rifetheme.com/apollo13-framework/docs/installation-updating/installing-the-plugins/
Part about installing bundled plugins - you should see such notice in admin area as shown in documentation. If you don't see it, try going to Appearance → Install Plugins.
There you should see plugins that are required for theme to work fully. You should install & activate them.
Hope now you will be able to proceed.
You might think I'm a dimwit, but I'm telling you that I don't see plugin bundles in admin or plugin section of WP.
So once again do I NEED to ACTIVATE the theme? or is something wrong with how the preview looks WITHOUT having ACTIVATED the theme?
Because if I've bought a bad theme then I'd like to get refunded. That's all I'm trying to suss out.
One again I'm thankful for any guidance you can give me.
Saskia
Link was jut informative - I wanted to help, as not everybody need to know everything.
What you mean by activating theme? You mean providing purchase code?
If yes, then it is not needed for options to appear.
If you don't mind I could take a look, cause this should be very easy case.
Like I said, after activation of theme, go to Appearance → Install Plugins - there are plugins to install. I would do that but your server requires FTP credintials to proceed, so you will have to do it on your own.
Hope now you can proceed:-)
You have now confirmed that is what's needed.
Hope it'll work now.
It is funny how people make assumptions that "this is obvious" and can not see when some one asks about this "obvious":-)
My bad, thanks for your patience !
