Purchase code can't be submitted
I have bought a Fatmoon license and would like to activate it, but unfortunatelly there is no option how to do it.
In the Fatmoon License & Info section there is an input field for the purchase code, but when I fill it in, there is no button to submit (there is only a text "submit text" which can not be pushed) - see attached screenshot.
I have checked all the wordpress requirements and it should be OK. The only struggle I have and might be connected is that I am not able to install the required plug-in - see attached screenshot.
Could you help please?
Thank you in advance.
Pavel
    Hello there:-)
    It looks like something is off, as theme assets are not loaded in your case. This license input should be styled and look like here in documentation http://rifetheme.com/apollo13-framework/docs/installation-updating/registering-the-purchase-code/
    Try getting newest version from ThemeForest once again and reinstall it.
    If this will not help try disabling all plugins, remove FatMoon theme, and install again.
  • Hi, thank you for your fast response.
    I have deleted the old version and install the new one and everything worked well.
    Thank you and BR,
    Pavel
    edited February 2018 Posts: 10,970
    Great to hear that!
    Have a good day!
