Hi!
So in our website, we've used a few hover boxes, however, when we're on mobile - the boxes don't turn when tapped.
It's important as we've made the text in the box on the back a link to another page.
Furthermore, is there any way to make the entire hover box clickable as a link?
Thanks.
Hovers are treated different on various mobiles, and on some they can not be tapped easily to activate, without opening link instantly.
Can you show me link with those boxes that you mention?
An example is this page: http://bespokelaw.com/our-people/
We'd like for the boxes to be clickable on both mobile and desktop, but we'd also like to see the 'flip' functionality work on mobile.
If it helps, we've currently tested it on iPhones.
So it is element from WPBakery page builder, right?
Could you tell me which one exactly it is?
As it is from external plugin it might not be easy to make it work on iPhone, but if I will know which one it is then I could try to make some solution for you :-)
On Adnroid Phones hover works fine right now :-)
It's the 'hover box' element in WPBakery. Sorry - I just realised that it was an external element. But I appreciate you looking into this for me.
onclickattribute works best. However you will have to modify plugin for this.Go to wp-content\plugins\js_composer\include\templates\shortcodes\vc_hoverbox.php line ~53
and change
<div class="vc-hoverbox">to
<div class="vc-hoverbox" onclick="">You can also think about adding this attribute with JavaScript, to be "update proof".
