Images not uploading to media library
in FatMoon Posts: 39
I am trying to upload images and for some odd reason they will not load. As you can see in the attachment, when I try to upload an image they show up blank. Not only does the thumbnail not load, but I cannot use the images on the site when I try to add it to a page or when I try to link to them. Not sure what might be the issue as this has never happened before.
Thanks,
Xeno
    Hey Xeno:-)
    Lets first be sure you are on newest theme version, and then we will debug if issue still remains :-)
    I've updated the theme to the latest version and I am still having this issue with the image uploads. Any suggestions?
    Thanks,
    Xeno
    Is there a chance that you are out of disk space on your server?
    If not, then let me take a look.
    Please send me temporary access to your WordPress. Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
    I already checked to make sure there was enough space on the server and there definitely is. I sent you a message with the temporary login credentials. Thanks for looking into it.
    Best,
    Xeno
    Hey Xeno:-)
    I have been on your site, and it seems you have some deeper problem there as your images probably are uploading, but paths are wrong. For example your logo image http://tankcarresourcecenter.com/wp-content/uploads/2017/10/RSI_reproducedlogo_White_SMALL.png returns 404 error.
    Please login to your server and check if such directory really exists.
    On your place I would also contact hosting provider as they have more access to every place so maybe they will give you answer faster what is wrong.
    However it seems that is not cause by any plugin.
