Disable Submenu Shadow and Background
in FatMoon Posts: 4
I'm trying to remove the shadow from the menu -> submenu. Also, is there a spot to make all the submenu backgrounds transparent?
    dang8 said: is there a spot to make all the submenu backgrounds transparent?
    Go to Appearance → Customize → Header Settings → Main Menu → "Flyout submenu"/megamenu background color and set color with 0 opacity (lower scroller of color control)
    dang8 said: trying to remove the shadow from the menu -> submenu
    Please use this custom CSS:
    .header-horizontal .top-menu ul {
        box-shadow: none;
    Sadly, that does not seem to work.
    I also tried
    box-shadow: none !important;
    and that also did not remove the shadow
    Please send me link to your site, where you have added this CSS. Maybe there is error or something is overwriting this.
    here is a link to the site:
    www.christymayfieldcoaching.com/new/
    we had to use the mega menu plugin because the client wanted the menu to open when hovering, and a much tighter box, and couldn't find those options in the theme. I removed any options that might be over riding the themes menu styles (made sure that the option for !important was turned OFF)
    In that case, when you don't use theme menu, then my custom CSS just couldn't work ;-) As this plugin produces different code.
    In this case you will have to modify it from this plugin settings, or with custom CSS.
    Anyway for shadow use this instead:
    .mega_main_menu li.default_dropdown > ul {
        box-shadow: none;
    Anyway I see this plugin have "skins", so maybe you can upload your own, or edit current one.
    THANK YOU!!!!!!!!!!! That worked perfectly!
