Hi there,
I have installed your theme and imported the BRONX demo, but I can't see the import of the revolution slider on the frontpage... + There are a couple of other templates that I can't find as well. Like the templates on 'album slideshow' or 'gallery'. This is the name of the site: www.photofly.be
Can you help me out with this?
I have already tried to re-install the demo, and have the same results. (I clicked on 'import sliders' on the import configuration menu, so don't know what the issue can be...)
Thx for your help!
Anneleen
About main issue- yes it was glitch in Import files that this Apollo13 Framework Extensions plugin was not activated during import. I have fixed it few days ago but for some reason server rejected my changes. Thanks for letting us know - it is now OK!
