After I included an embedded Mailchimp sign-up form to my Home page I noticed that Elementor editor loaded in but on the right side (where I can make changes) it became empty and white. The content wasn't showing even if I could see the space for it was there. In reality the content is there but Elementor is not showing it. ( I loaded up a snapshot of what I see). I pasted the Mailchimp embedded code in a text box.
I am wondering if there is any specific way I could fix this issue. On the long run it might cause me a headache. Currently I am happy with the homepage and I did some minor changes using the WP Editor instead but it messes sometimes the formatting.
It seems like clash between those 2 plugins, and it maybe best to talk with their developers. However if you tell me what is exact name of mailchimp plugin then I will take a look also.
Thank you for your answer. I will contact Mailchimp as well.
Thank you also for wanting to take a look at it.
I am not using any plugin. I just generated straight on the mailchimp website (mailchimp.com) within my list>sign-up forms> embedded forms the content and it automatically generated the code below I just pasted in the text tab (in WP editor- adding a snapshot pic).
Such code will only cause problems, and you should use plugins to add newsletter. Adding such code in WordPress editor/Elementor is not safe, and rather not accepted by those scripts, and can make such issues.
Many thanks for your advice! I am a newbie keen to learn and this was a good lesson.
Also let me pause here and let you know how much I do enjoy using the RIFE theme! My website is looking really really nice! So THANK YOU for creating it and providing all the help as well! I do appreciate them a lot!
Now back to the remaining challenge:
What I did: - I removed the Mailchimp code and used the plugin you suggested above. Now I have a shortcode pasted in the text and it works.
Current challenges remaining: - Unfortunately Elementor is still blank when I try to open it on the Home page. Other pages work well. I am wondering if I need to do anything to the plugin to try to motivate it to work again.
- Unfortunately the Header style on the Home page changed to Upper Case only even if I am using the default settings (H2 for ex). I would love to fix that. I doubt my audience would appreciate the Upper Case style.
I am very sorry for the mess! Many thanks in advance! Kind regards, Linda
I am glad you like Rife theme so much. Hope it will get only better for you.
As for Elementor issue: if you like I can take a look, cause I suspect there can be some JavaScript error remaining after previous code was inserted.
By sending access to WordPress I mean: -create new ADMIN account with fake e-mail -set some password to this account -send me created login and password
LindaHo said: Unfortunately the Header style on the Home page changed to Upper Case only even if I am using the default settings (H2 for ex). I would love to fix that. I doubt my audience would appreciate the Upper Case style.
Could you show me link to page where I could see it, so I could understand better which element it is exactly? Did this happen after mailchimp issue?
Thank you!
Linda
- snapshot of where I pasted the code (JPEG)
- the code (Word doc)
Better use plugin like https://wordpress.org/plugins/mailchimp-for-wp/
What I did:
Kind regards,
Linda
-send me created login and password Could you show me link to page where I could see it, so I could understand better which element it is exactly? Did this happen after mailchimp issue?
